AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Frontloader won't spin for 'Final Spin'
Hello, my Kenmore frontload washer was making a loud grinding noise on final spin, then intermittent wouldn't spin on final, now won't spin on final. Agitates and pumps fine. Drain hose isn't kinked, may have been before. Were coins in the catch in front of the pump, cleaned that out.
Anything else I can look at/test?
You may have a problem with the latch assembly. I wrote about this problem in my post Frigidaire Washer Won't Spin on my blog. If everything is clear in the drain and sump and it only tumbles around during the final spin, this is likely the problem.
Thanks, read your blog and that sure sounds like problem we are having. Will test
Washer Repair
