caysal
#1 Posted : Friday, June 17, 2011 8:13:39 AM(UTC)
caysal
[FONT='Arial','sans-serif']Gear device at center top of bottom unit is striped. I was told by your company that the coast was only $6 USD. I would order it if I knew how to replace it. I tried to pop it off with a screwdriver and had no luck. Thank you. [/font]
repairmanjoe
#2 Posted : Friday, July 8, 2011 3:51:34 PM(UTC)
repairmanjoe
It's a very simple fix, but some are reluctant to do it because it does take a little prying. Watch the video below which should give you an idea of how easy it is to repair.
YouTube - ‪KitchenAid blender coupler replacement‬‏
dyanne007
#3 Posted : Monday, July 18, 2011 1:03:02 PM(UTC)
dyanne007
The rubber coupling has disinagrated and I need to order a new one but am not sure if the part below it is part of the coupling or the coupling
fits on top of it
