Control Panel not working. Are there any trouble shooting steps I can follow the locate problem.
Originally Posted by: jose2741  Control Panel not working. Are there any trouble shooting steps I can follow the locate problem. Jose', Here is a list of error codes, that pertain to your range ERC/Clock, You didn't mention, what exactly was wrong. F1 - Shorted pad button.
F2 - Oven cavity over temperature.
F3 - Open circuit in oven temperature sensor circuit.
F4 - Shorted circuit in oven temperature circuit.
F5 - Defective watchdog circuit in control.
F7 - Failure of door lock switch sensing with door locked.
F9 - Failure of door lock switching sensing with door unlocked.
Just so you're aware, the majority of parts for this range, have been discontinued, and are no longer available from the manufacturer.
Good Luck, :) :) :)
