Rank:: Member
I was cleaning the refridgerator and had the doors open for about 2 hours. Both fridge lights just stoped working at the same time. Everything else works great. Any Ideas?
Here are your parts, includes a wiring diagram Model ASD2620HRWLooks to me like you should have 3 bulbs in the fresh food. First try a new bulbs or check the old ones with a meter. If one bulb burns out it could also take out the second one if the filament is weak. If no go, trace back the wires. Note that the lower bulb does not use one of the plugs, if this one works then the problem is the wires/plug to the upper bulbs. |
THIS FORUM IS DEAD!!!!!!! |
