:cool: Dryer runs and will dry, but after 30-40mins shuts down and wont start back up for awhile. Also timer set knob doesn't move while running. What might be the problem? Thank you!
It sounds like the motor is getting hot, and then cutting off on overload. You could try to take the front off and clean all the lint out, and clean the motor off. If that does not work, then you need to replace the motor. Tom
