Vectordr
#1 Posted : Wednesday, June 15, 2011 7:23:52 PM(UTC)
Vectordr
Washer fills but does not start wash cycle. Push cancel and water drains. Lights seem to work. Replaced control board and did not fiix problem. Can you suggest the next step? Thanks
Joe / APP Team
#2 Posted : Thursday, June 16, 2011 6:17:48 AM(UTC)
Joe / APP Team
Vectordr,
Remove the kickplate and lower access panel,
Check for loose connections, bad wires to the wash motor.
(you should find the "Tech Data Sheet" attached to the back of the kickplate, and will be able to check the motor winding resistances and voltage to the motor).
Good Luck,
