pogi2008
#1 Posted : Saturday, February 28, 2009 2:50:54 PM(UTC)
pogi2008
Hi, The fridge is cooling fine but the freezer is cold but does not freeze. i can hear the compressor and the fan running the whole time. I just change the motor on the comp. fan. I did some reading i am leaning towards the defrost timer being faulty. I check the coils at the back of the freezer but there is no ice build up. Help? :confused:
#2 Posted : Saturday, February 28, 2009 4:04:19 PM(UTC)
If there is no ice build up, you do not have a defrost problem
Make sure your condenser coils are clean.
You may have a low freon
Here is a good link. Check out #20 especially the "example picture"s at the bottom of the post.
http://www.applianceaid.com/refrigerator.html
pogi2008
#3 Posted : Saturday, February 28, 2009 7:05:41 PM(UTC)
pogi2008
Thanks for the response denman, so if it is low freon, is it worth saving it? I do not think that this something that you can do yourself (freon filling). Great info on that link you've provided. Thanks
#4 Posted : Saturday, February 28, 2009 8:49:36 PM(UTC)
Adding freon must be done by a tech with the proper equipment and certification.
You could call a couple places and get a quote.
Problem is cost.
Also if it is a small leak and is not found it will just happen again.
May well be time to look at a new unit.
