MY TUB STOPPED TURNING AND I DON'T KNOW HOW TO FIND THE BELT ON THE DRYER :confused:
Hi charliegirl Are you sure the problem is the belt? Does the motor run? To get access to the parts inside the dryer you have (using a putty knife) to push and release one locking clip on each side on top of the front panel and lift the top panel up. Remove screw on each side of the front panel, pull the top of the front panel toward yourself and release it from the clips on the bottom. - The part number for the belt AP2946843 Good luck. Gene.
