Oster minifridge won't stay running. If i turn dial to "off", then turn it on again, it will start running until it is cold. however it will not start up automatically when the temp dips.
what could be the problem? thermostat?
side note, if i dont close the door, it seems to continue running indefinitely.
thanks in advance,
jesse
I cannot find any info on this unit.
[COLOR="DarkRed"]what could be the problem? thermostat?[/COLOR] Yes it does sound like the thermostat is sticking open. |
THIS FORUM IS DEAD!!!!!!! |
