jtorinda
#1 Posted : 16 years ago
jtorinda
Hope someone can help.
I have a control panel that appears to have a blown fuse on the left top corner of the display. It also has a 1/4"X 1/4" blackened spot on the glass display which is about 3/8" alway or on top of the fuse.
Controls appear to work but sometimes not the expected results. Hitting upper oven may turn lower oven.
:confused: Bad control?
#2 Posted : 16 years ago
Here are your parts for this series
Model Search
I cannot see anything on the board that looks like a fuse so a resistor or diode probably blew up.
Schematics for appliance boards are not available.
I would replace the control board.
jtorinda
#3 Posted : 16 years ago
jtorinda
Thanks, I will try and remove the control panel to confirm model number. Will get back to you tomorrow with the results.
