thanks in advance ISSUE(S): 1. washer has 4 fill amount settings, sm/md/lg/spr. It only fills to about 2/3rds of the agitator turbines height (overall agitator part is another few inches taller). Seems like it fills to the medium level, 3-4 inches lower than full tub. 2. washer has 3 temp settings, cold is cold, hot is hot, but warm is mostly cold. Jim, Cocoa, FL
Hi Jim,
1. Clean out the tube going from the pressure switch to the tub and see if that helps your water fill problem. If not you will probably need to replace the water level switch.
2. Turn off the cold water valve, set the temp switch on warm and see what happens. If absolutely no water comes in, te problem is likely with the temp switch, although it could be the timer.
