Ravensdale
#1 Posted : Thursday, February 26, 2009 5:03:15 PM(UTC)
Ravensdale
icemaker quit working last couple days water in tray, checked for frozen fill pipe, censor on inside of door flashs like normal have any trouble shooting tip THANKS
kayakcrzy
#2 Posted : Friday, February 27, 2009 4:37:20 AM(UTC)
kayakcrzy
The fingers that knock the ice out should be in the 2 o'clock position. Which means that the fingers should be looking at you, and be just above the horizon of the icemaker. If not replace the motor module. If they are at the correct position, and the black hose that drops the water in is not frozen, the emitter kit will be your problem. That is the flashing light piece, and the reciever on the other side. The part # is 4389102 Tom
Ravensdale
#3 Posted : Friday, February 27, 2009 4:53:08 PM(UTC)
Ravensdale
The fingers are at 7 oclock what is the white screw on the moter for can I manuely turn that to make the ice maker work Thanks for helping
kayakcrzy
#4 Posted : Saturday, February 28, 2009 4:15:39 AM(UTC)
kayakcrzy
You need to replace the icemaker motor module. The white screw on the side is a water time adjustment. Tom
