t6865mc
#1 Posted : 16 years ago
t6865mc
After 20+ min of oven use or range top, I get E4 F3 fault code. After while it changes to E0 F3. I lready chacked the oven sensors for correct ohm resistance, they are good. Any idea what is wrong? Thanks:confused:
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
E4F3 means a bad sensor. I would replace the sensor. Tom
Colorado88
#3 Posted : 7 years ago
Colorado88
Where is the oven temperature sensor located
