We have a kitchen aid dishwasher that is not cleaning the dishes. I have replaced the upper arm asm because it was bad. I also replaced the nylon radial bearing, bearing ring and the restrainer nut. when we run thru a normal wash cycle and open the door to stop it appears that neither the top arm or lower arm are rotating. It fills with water and will pump it out. [FONT='Times New Roman']So can someone tell me what wrong.[/FONT]
