Hello, any help would be greatly appreciated. Our oven, the Thermador PGR364GL is never the same, You set the temp to 450 it will heat up and only go to 250 -300 then it shuts off or the temp never goes up after that . Also, the broiler, will light up for a minute or two then it turns itself off, sometime will come back on for another minute or two then off again, I am thinking either igniters, or thermostat ...unless there is something else that triggers it to stop...the burners on top are working fine by the way. I a m ready to order the parts but any help from this forum will be greatly appreciated. Thank you
Sorry for bring up an old topic I also have a PRG364GL.
Did anyone figure out how to fix this? I have the same issue.
Need help my Thermador MODEL P364GEC over/broiler won't stay on. Set the temp to 450 it will starts then shuts offs. Also, the broiler, will light up for a minute then it turns off. I changed the both igniters but the same thing. I am thinking it might be the thermostat ...unless there is something else that triggers it to stop...the burners on top are working fine. I am ready to order the parts but any help from this forum will be greatly appreciated. Thank you.
