kickinsgirl
#1 Posted : Tuesday, February 24, 2009 5:41:00 PM(UTC)
kickinsgirl
My 3 Yr Old Frigidaire Over The Range Microwave Suddenly Stopped Working. The Timer Will Count Down But It Doesn't Power On. I Had The Door Sensor Replaced About 18 Months Ago And Then About 4 Months Ago It Started To Keep Running When The Door Was Open, But It Still Worked So I Kept Using It. THEN A Couple Days Ago It Quit All Together. Any Ideas On What Might Be Wrong With It Now?
TechnicianBrian
#2 Posted : Tuesday, February 24, 2009 6:01:16 PM(UTC)
TechnicianBrian
One of your interlock switches is out of adjustment. Behaving and to the left of the control panel is a bracket that holds the switches. When the oven is running, if you pull down or push up on the door, you may find it starts to work, or begins to do something else strange. All three switches must be actuated in the correct order for the oven to operate properly, so you may need to loosen the screws to the bracket and move it around to find the sweet spot to get the switches to actuate when the door is closed.
