Donny C
#1 Posted : 16 years ago
Donny C
Of course, my warranty is up. First the broiler just shut down, no warning, mid broil. The convection oven seemed to be ok when I turned it on, the fan started up ok. But that shut down within a minute. The gas stove top portion works fine. Suggestions?
TechnicianBrian
#2 Posted : 16 years ago
TechnicianBrian
A model number would be most helpful. If it is only the oven that is no longer working, I would suspect a thermal fuse has opened the L2 circuit to the elements. It is usually located behind the control panel with a red reset button.
Donny C
#3 Posted : 16 years ago
Donny C
Thanks Brian
A contractor friend with the right tools tried to get into the control panel, located behind the control knobs on the front. I need to get off the control knobs because there seem to be screws that originate behind them and go through the front of the panel and into little L brackets to hold it on. Kind of a nifty lock to keep me out, is the way I look at it. I will be sooooooo p-ed if I have to pay $200 for someone to come and hit the reset. The $200 is what the repair service around here charges just for "diagnostics".
Any further suggestions on getting down in there?
TechnicianBrian
#4 Posted : 16 years ago
TechnicianBrian
You still haven't provided a model number so I am not entirely sure what you are looking at, but in many cases, there are some screws behind a couple of the knobs that go through the bezel and into a bracket holding the panel place. As for paying for a diagnosis, if someone does come out and reset the thermal fuse, I would expect them to also figure out why it happened. May be a fluke, but if a safety component trips, I like to figure out why.
Bosch dual fuel range burners all spark but 2 burners don't ignite (Oven Repair (including Ranges and Cooktops))
by elizabeths 4 years ago
Kitchenaid dual fuel range - display and oven dead, burners working (Oven Repair (including Ranges and Cooktops))
by cliffo 4 years ago
THERMADOR 36" Dual Fuel Range (Oven Repair (including Ranges and Cooktops))
by jascato 11 years ago
Jenn-Air dual fuel range (Oven Repair (including Ranges and Cooktops))
by Stever1951 11 years ago
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 12 years ago
Sears Kenmore Pro Dual Fuel Range Problem Up (Oven Repair (including Ranges and Cooktops))
by akkelley3 12 years ago
Sears Kenmore Pro Dual Fuel Range Problem Heating Up (Oven Repair (including Ranges and Cooktops))
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 13 years ago
kenmore pro dual fuel range overheating (Oven Repair (including Ranges and Cooktops))
by kenmoreprofails 13 years ago
Dacor Dual Fuel Range Beeps & Shuts Off (Oven Repair (including Ranges and Cooktops))
by Coolhand 13 years ago
How to repair Jenn air Dual fuel range (Oven Repair (including Ranges and Cooktops))
by storm965 13 years ago
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 13 years ago
Thermador dual fuel range (Oven Repair (including Ranges and Cooktops))
by gmg3 14 years ago
Frigidaire dual fuel range (Oven Repair (including Ranges and Cooktops))
by mcedison 14 years ago
kenmore Dual Fuel Range - oven does not heat (Oven Repair (including Ranges and Cooktops))
by richardjefferson 14 years ago
