I have a Jenn-Air electric oven and the clock doesn't work so my wife cannot use the time bake on the oven. Is there anything else that could be wrong besided just the clock. How is it repaired.
Here are your parts Model D140Here is a service manual http://www.servicematters.com/m...s/16000446(ER001-00).pdfThe timer shows Requires Special Attention often means obsolete but it is worth giving them a call. Is there anything else that could be wrong besided just the clock. Usually it is the timer. You could check that all the connections are OK. How is it repaired. Replace it If unavailable there are places that repair mechanical times. Perhaps someone else will jump in and recommend one. |
THIS FORUM IS DEAD!!!!!!! |
