I have an 18 month old Kenmore Quietguard dishwasher. Panel lights up when you push the buttons but nothing ahppens as far as washing, etc. I think it is the control panel or possibly the switch? Any other suggestions or things to consider?
Does it fill up with water?
If it does not then I would check the door switches first.
It does fill with water and then proceeds to wash cycle for about 30 seconds then stops. Two green lights flash on the hi temp button and the heat dry button but I'm not sure what the lights indicate? Can't find a manual anywhere.
Look for the tech sheets inside the door or the control panel. Sears does not publish it on-line.
Originally Posted by: Don Moma  I have an 18 month old Kenmore Quietguard dishwasher. Panel lights up when you push the buttons but nothing ahppens as far as washing, etc. I think it is the control panel or possibly the switch? Any other suggestions or things to consider? I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
