AppliancePartsPros.com
Appliance Repair Help
Washer Repair
baffle is loose - Kenmore HE3 Front Load Washer
One end of a baffle has come loose from the inside of the drum. How do I access the retaining screw location to re attach it? Is there an access hole to reach these screws or do I have to remove the drum. Any step by step instructions and/or pictures would be much appreciated.
Thanks!
Originally Posted by: tripdip  One end of a baffle has come loose from the inside of the drum. How do I access the retaining screw location to re attach it? Is there an access hole to reach these screws or do I have to remove the drum. Any step by step instructions and/or pictures would be much appreciated.
Thanks! Tripdip, Here are the instructions on replacing the baffles in your washer tub.
It's an older excerpt from a post in the APP Repair Forum, and should apply to your washer
If you have not already finished this repair, here's good news: it's EASY. Go ahead and order those parts. Get the kit with all three baffles -- its likely that the plastic tabs on more than one of them have been damaged, because Whirlpool apparently never installed the retaining screws that hold the baffles in place. It appears to be a common problem. 1) Remove the three screws on the back of the washer for the lid. 2) Remove the lid. 3) A black rubber hose enters the outer drum top and center near the front. Gently remove it from the drum. 4) Through the resulting hole, you can reach the exact spot for inserting the retaining screws for the baffles. 5) One by one, replace the baffles (they drop into place, then need a little force to slide them forward into place) and rotate the inner drum so that the retaining screw hole is visible below the opening in the top of the outer drum. 6) (Without dropping the screws into the space between the drums like I did ), install the screws to retain the baffles. 7) Repeat for the other two. 8) Replace the hose and the lid and its screws and rest assured that you did something that even the Whirlpool assemblers didn't do: install the baffle retaining screws. Good Luck, :) :) :)
Washer Repair
