2358schwab
#1 Posted : Tuesday, June 7, 2011 7:41:56 AM(UTC)
2358schwab
I just finished replacing the motor coupling (would not agitate or spin) on my Kenmore 90 series washer. After running through a full cycle i found that my first problem was solved. However, when the washing machine stops after each spin cycle that it jumps out of place. :confused: There is also a high winding noise that starts and stops when the spin cycle is over. I am really at a loss on what could be the problem and was hoping for some assistance!
sidfink43
#2 Posted : Wednesday, June 8, 2011 5:42:56 PM(UTC)
sidfink43
Sounds very much like a brake problem. Repairing them is not much more than going a little further than a coupling change out.
See the Sticky at the top of this page by Richappy on direct drive brakes.
