Fills OK, but doesn't run through some cycles, like wash/rinse, and doesn't always drain. Replaced circuit board - no change:(
Checked resistances on motor windings - main and wash are good, but drain shows 2.5 ohms, wiring diagram says it should be 4.2 - 7.0. 120 volts present at all windings at appropriate times. Motor shows clear signs of past leak from above - but dry now. Does any of this sound like my problem?
I've tried just about everything else; motor/pump turns freely, drain open, fills OK, heater OK, door interlock OK, etc., etc.
HELP - I'm getting frantic. (If I call a pro what is he going to do?)
Thx in advance Dave
Hi Dave If the power coming to the motor and the motor does not work, then there are no questions - the problem is the motor. If this is what you have with your dishwasher, then the pump and motor Assembly is the part what you needed. - The part number for the pump and motor assembly AP3776341 Good luck. Gene.
Thank you Gene - really appreciate the advice.
Got the pump/motor apart - pump looks brand new, motor pretty corroded on the outside but what I can see internally looks OK. Drain hose was apparently loose when the unit was installed new. Went 6 months before it came off. What a mess, but no leaks since (8-9 years.)
Anyway, while I'm at it, I'd like to rig up 120v to the motor just to see what I get, but I was never sure how the reverse sensing winding (or whatever it's called) works. Is there some way I can test each direction of rotation on the bench?
BTW, motor turns and sound good, ie. no bearing/loose pieces noises, etc.
Thx again
Dave
Gene is right on - Took the bottom motor plate/bearing off just to take a look. Found overheated windings (charred enamel) and some of the winding lacing burned/melted through.
All coils had continuity, as I mentioned before, but the resistance was a little low on one. Kinda subtle.
Thx again
Parts on order from APP -
Dave
Keep me updated, please.
Like Gene said - problem was with the motor. New motor (& pump), runs like a charm.
The fact that the drain winding showed continuity threw me off. Apparently continuity isn't enough, the resistance has to be right too.
Thanks a mil for the forum, and for Gene
Dave
