AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Soap door opens but soap just runs down door and sits on the bottom
Help, when I run my dishwasher, it runs through the whole cycle but when I open the door, the soap dispenser door is open but it looks like the soap just runs down the inside of the door and sits on the bottom of the washer. I get some patches of soap that sticks to the dishes on the bottom rack. It seems to work fairly well if I set it to pots and pans but then I'm faced with a 2 1/2 hour wash cycle and all my plastics are shrinking. I thought it was because of cheap soap but even the expensive soap sits at the bottom. What do I need to do?:confused:
THIS FORUM IS DEAD!!!!!!! |
I tried to get the Manual and signed up on the sight you gave me but it said I didn't have access to that particular area :(
Try is again as it sounds like you had registration problems.
Sometimes you have to give a site time to register you. |
Dishwasher Repair
