Neep help putting wires back onto new overload part. purchased new compressor start device from local store. refrigerator model et1ftkxkq00. New part has all black two pronged piece and a sigle prong white and black piece. have found how to put on compressor but need help puting wires back on new pieces. I have three wires. one small female connector and two larger female conectors..new part has all larger male conectors. need help
thank you Adam
If you wire in the new start device wrong, you will burn out the compressor. See if the part AP3961332 is the same as your old one with the same size spade connectors and proper run capacitor connectors. If so, order it.
