pinbill
#1 Posted : Saturday, February 21, 2009 6:48:46 AM(UTC)
pinbill
Hello-
My Kenmore side by side fridge/ freezer dispenser has never worked. Now the water tap is leaking steadily. I would just turn off the water and buy some ice cube trays but the water line is connected to the dishwasher and I don't want to have to turn the water on and off to run the dishwasher. Is there an easy way to plug the water line?
I am looking into changing the valve and have the cover to the dispenser off but can't get to the valve, any suggestions? Do I have to remove the inside freezer panel or just pry off the plastic housing from the outside?
Thanks,
Bill
beenthereagain
#2 Posted : Sunday, February 22, 2009 5:36:26 AM(UTC)
beenthereagain
Groups: Expert
well first thing is the water line to the refrigerator is the same one to dishwasher? the dishwasher must be connected to the hot water , and refer to the cold.
the water valve is not located in the dispensor area. it is behind the frig. it is a dual solenoid valve , one half for ice and the other for water.
pinbill
#3 Posted : Sunday, February 22, 2009 8:24:37 AM(UTC)
pinbill
Thank you for responding, I may be wrong that the washer and fridge have the same water line. I am going to take the back of the fridge off and test the valve. Is there anything I should know about taking the back of the fridge off?
pinbill
#4 Posted : Sunday, February 22, 2009 9:05:01 AM(UTC)
pinbill
Hello again-
I located the valve and am on the phone finding a new one. I will let you know how it goes,
Thanks for you help,
Bill
pinbill
#5 Posted : Sunday, February 22, 2009 11:55:30 AM(UTC)
pinbill
Thanks again for your help, problem solved.
