deanb
#1 Posted : Friday, February 20, 2009 1:55:01 PM(UTC)
deanb
How do I replace the bottom mount freezer door handle on an amana abb1924des.
door handle part # ap4080589
thanks
TechnicianBrian
#2 Posted : Friday, February 20, 2009 3:09:33 PM(UTC)
TechnicianBrian
Pull outward on the right side of the handle and slide a credit card you don't mind getting damaged under the inside of the right mount about 1.5 inches or until it stops. Then while holding both ends of the handle, try sliding the entire thing to the left. If you have some blue painters tape available, put it on the door to prevent scratches. The new handle slides on to the right. If this doesn't make sense and you have your use and care manual the information complete with illustration can be found inside.
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 8/9/2021 11:02:12 AM(UTC)
Removing/Replacing Freezer Door Handle (Refrigerator & Freezer Repair)
by tightropewalkerr 12/1/2014 4:15:58 PM(UTC)
Freezer door handle (Refrigerator & Freezer Repair)
by yamitibug 9/2/2014 10:20:22 AM(UTC)
Freezer door handle falls off (Refrigerator & Freezer Repair)
by revjohnc3 4/16/2013 3:30:33 PM(UTC)
amana freezer door handle (Refrigerator & Freezer Repair)
by rfmisland 7/11/2012 11:31:31 AM(UTC)
Freezer Door handle clip (Refrigerator & Freezer Repair)
by ckwysock 5/21/2012 5:59:05 PM(UTC)
Loose freezer door handle (Refrigerator & Freezer Repair)
by stuhenderson 9/5/2011 2:50:08 AM(UTC)
Loose Freezer Door Handle (Refrigerator & Freezer Repair)
by wgorczycki 10/29/2009 6:53:49 AM(UTC)
Replace freezer door handle (Refrigerator & Freezer Repair)
by dhurwitz 3/13/2008 12:12:50 AM(UTC)
