My roper dryer #RGS7646K2 when first turned only lights briefly but then goes off. If I open the door and then restart it will light again but still go out I have cleaned the lint trap.
does anybody have any ideas?
thanks
The first thing I would do is replace the gas valve coils (#13 & #14 on the diagram). - The part number for the coil kit is AP2150379Gene.
Originally Posted by: Gene The first thing I would do is replace the gas valve coils (#13 & #14 on the diagram). - The part number for the coil kit is AP2150379Gene. Thanks Gene , That is what I thought it might be but wanted somebody with more knowledge to back me up. Will order parts next week after payday. thanks agaain
