cherreth
#1 Posted : Wednesday, February 18, 2009 12:57:56 PM(UTC)
cherreth
I turn my Kenmore dryer on to dry, push the start button but will not stay on. I checked the door switch and it works. The dryer operates as long as I am pressing the button but goes off when I let up. What is causeing this to happen?
kayakcrzy
#2 Posted : Wednesday, February 18, 2009 4:30:11 PM(UTC)
kayakcrzy
It is most likely the micrcomputer. The part # is 8546229 It is located behind the control panel. Tom
#3 Posted : Wednesday, February 18, 2009 6:23:40 PM(UTC)
Cannot find a parts breakdown
Your dryer is made by Whirlpool. Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%203979101.pdf
Even Heat controlled units have had this problem
Here is a link check out #40
http://www.applianceaid.com/whirlpool-dryers.html
Roper Dryer will not stay on... HELP. (Dryer Repair)
by stephanie4867 2/22/2011 7:16:56 AM(UTC)
