grandfather
#1 Posted : Wednesday, February 18, 2009 10:14:37 AM(UTC)
grandfather
GE GAS DRYER COOL DOWN BUZZER OPERATES CONTINUOSLY WHEN IN ANY CYCLE WHICH REQUIRES HEAT. REMOVED SIGNAL SWITCH FROM PANEL. CHECKED FOR RESISTANCE FROM OFF TO LOUD BUZZER. NO DISCERNIBLE CHANGE IN RESISTANCE MEASUREMENTS. REMOVED SWITCH FROM CIRCUIT. SAME RESULT. BYPASSED SWITCH, SAME RESULT. SWITCH HAS NUMBER 572D567P002, GE PART #WE4M257. OBSERVED GLOW COIL AND GAS BURNER. WHEN BURNER OFF, BUZZER DID NOT WORK. WHEN BURNER ON, AND HEAT DEVELOPED, BUZZER "BUZZED" CONTINUOUSLY. PLEASE ADVISE:confused:
continuous buzzer (Dryer Repair)
by randy165 9/6/2009 9:53:01 AM(UTC)
