rnyland
#1 Posted : Friday, June 3, 2011 7:37:51 AM(UTC)
rnyland
My dryer makes a strange noise when you push the start button. It starts but when it is running it sounds like there is a flat spot as the drum is turning. Every rotation part of the sound gets louder like a roaring sound. Then when you open the door to stop it, as the drum is coming to a stop, there is a dragging or rubbing sound before it stops. We had the dryer apart and checked the blower wheel, the adler pulley and the rollers. They all seem to be O.K. Are the bearings in the motor going bad? Do I need to replace the motor?
rnyland
#2 Posted : Friday, June 3, 2011 7:41:06 AM(UTC)
rnyland
:confused:
Joe / APP Team
#3 Posted : Friday, June 3, 2011 7:57:20 AM(UTC)
Joe / APP Team
Rita,
Sounds more like you've got a flat spot on the rollers, or the blower whell has rounded off and the wheel is loose on the motor shaft.
(once you get access to the motor and blower wheel, hold the motor drive pulley, and turn the blower wheel, there should be no movement in the blower wheel, if you can rock the wheel back and forth while holding the motor pulley still, you'll need a new blower wheel,
Part number: AP4294048
I doubt you'll need a motor , at this point.
mikerita (Refrigerator & Freezer Repair)
by rita nesmith 3/24/2012 11:32:04 AM(UTC)
Caloric Heritage Series Gas Stove Oven (Oven Repair (including Ranges and Cooktops))
by citizen01 9/27/2010 9:17:13 AM(UTC)
Caloric Heritage Series Electronic Ignition (Oven Repair (including Ranges and Cooktops))
by tatrepair 10/27/2009 5:29:09 AM(UTC)
Caloric Range Heritage Series (Oven Repair (including Ranges and Cooktops))
by stupidcupid58 6/12/2009 8:39:56 AM(UTC)
GE dishwasher "Profile tritan quiet power II" (Dishwasher Repair)
by Chuck Powers 1/6/2009 10:08:33 AM(UTC)
oven irritation (Oven Repair (including Ranges and Cooktops))
by mainzy 7/21/2008 8:41:05 AM(UTC)
Irritation Progressing To First Phase Of Anger (Dryer Repair)
by napradoc 5/10/2008 5:26:49 AM(UTC)
