John Wyre
#1 Posted : Wednesday, February 18, 2009 8:54:27 AM(UTC)
John Wyre
When opperating the microwave, an arc is observed at the turntable motor. Is there a problem with the motor or is there a seal that may need replacement?
Thanks John
#2 Posted : Wednesday, February 18, 2009 11:38:51 PM(UTC)
Hi John,
Remove the glass tray and check the coupler and the condition of the paint on the bottom. Post the results.
John Wyre
#3 Posted : Thursday, February 19, 2009 3:50:53 PM(UTC)
John Wyre
Hi John,
Thanks Gene,
I had noticed a few small (pin head) pits in the paint under the coupler. I coated the pits with a thin coat of Ceramic Epoxy (Torr Seal)..... The Arc is Gone. Thank you, John
#4 Posted : Thursday, February 19, 2009 9:23:21 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (4)
