ndcrowther
#1 Posted : Tuesday, February 17, 2009 5:27:15 PM(UTC)
ndcrowther
The drum has recently began filling with water when the washer is off. Today is was about 1" above the basket after approximately 24 hours. I would guess the water inlet valve is sticking open, but it would only be a guess. Can you assist?
Thank you.
TechnicianBrian
#2 Posted : Tuesday, February 17, 2009 5:34:58 PM(UTC)
TechnicianBrian
If you want to be sure, unplug the washer and see if water still trickles in. If so, then one of the valves is not sealing completely. Four screws total, one hose clamp and you can get that valve (AP3128776) changed before it decides to leak more.
ndcrowther
#3 Posted : Tuesday, February 17, 2009 5:38:00 PM(UTC)
ndcrowther
If it stops trickling in, what would be causing the problem?
Thank you.
TechnicianBrian
#4 Posted : Tuesday, February 17, 2009 5:44:19 PM(UTC)
TechnicianBrian
The valve is not sealing shut, so either the valve has something stuck inside preventing it from sealing, or the water pressure from your water connection is to low to create a good seal. So unless you have noticeably low water pressure, I would go with the valve. Running the washer may flush out any obstruction so you may notice the problem just goes away. but if it doesn't, replace the valve.
ndcrowther
#5 Posted : Tuesday, February 17, 2009 5:51:36 PM(UTC)
ndcrowther
No noticeably low water pressure anywhere else in the house. First discovered the problem over the weekend and the drum was half full. Luckily the door was shut. Usually is left open. Have run the washer 6-8 loads since then and it still leaks. Agree. Good time to replace the valve.
Thank you.
whirlpool duet drum filling up over night (Washer Repair)
by dldcns 2/1/2015 7:26:14 AM(UTC)
Maytag 4000 Series Washer - Drum Filling With Water (Washer Repair)
by DohertyRacingStable 9/14/2013 12:15:58 PM(UTC)
