wahljs
#1 Posted : Monday, February 16, 2009 6:58:26 PM(UTC)
wahljs
I needed a new drain pump for my dishwasher so I ordered AP2802385 from this site as the pictures looked identical to the original one I took off. The pump came in the mail today and the box is labled part #167082. The impeller and electrical connections are different. Other than that it looks like it will fit. Did I get the correct part? Do I wire it up the same as the original? (Dual wire lead on left side and single wire to the right).
blekenbleu
#2 Posted : Sunday, April 5, 2009 3:39:27 PM(UTC)
blekenbleu
167082 is correct the Bosch Part-No for SHX46B05UC/21 drain pump, according to the Bosch spare parts listing.
wahljs
#3 Posted : Monday, April 6, 2009 6:39:55 AM(UTC)
wahljs
I went ahead and installed it and hooked up the wiring using the left and right tabs just like the one I took off and everything worked fine.
