AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag dryer turns and heats but clothes not dry
Have a Maytag dryer that takes many many times to get clothes dry. When you open dryer, it is hot, the thing turns but clothes do not get dry. Help?
Here are your parts Model SDE3606AYWMost common cause is a dirty vent system. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
