How Do You Clean The Drain Pan? It Does Not Appear To Be Removeable. It Is Screwed To The Undersideof The Fridge. Also How Do You Remove Odors From It If It Is Not Removeable
:mad: I also would like some info about this problem. Since i cannot seem to find an owners manual (without paying for it), I find this site with someone else asking about it. Can anyone give us an answer or info on acquiring owners manual? :confused: Originally Posted by: dbogino  How Do You Clean The Drain Pan? It Does Not Appear To Be Removeable. It Is Screwed To The Undersideof The Fridge. Also How Do You Remove Odors From It If It Is Not Removeable
