I am trying to find help with replacing/cleaning the fan motor of our Buck Stove insert. I can not find the parts breakdown anywhere. I do not know how to get to the motor.
Originally Posted by: carolb4  I am trying to find help with replacing/cleaning the fan motor of our Buck Stove insert. I can not find the parts breakdown anywhere. I do not know how to get to the motor. Model number helps
51ZC is the model number.
I assume you have already gone to the Buck Stove website. They will at least be able to supply you with a local dealer and perhaps they can help you over the phone. There is a fair amount of info there but take a bit of hunting.
On most inserts the bottom vent panel either un-clips or is hinged (usually hinged). This gives you access under the stove and you should see the fan.
Sometimes they are a pain to get at requiring long arms and stubby tools.
Note if the problem is that your fan is not running they are often fused also you probably have a rheostat to control the fan speed. |
THIS FORUM IS DEAD!!!!!!! |
Groups: Expert
I do not know. That is beyond my scope of knowledge. What do I need to look for.
Groups: Expert
Is it brick and mortar or a steel firebox? If it is a steel firebox, does it have 4 air ducts--two high/ two low? Is there a metal rating plate identifying the mfr.?
