I have a Kenmore elite side by side. The water dispensers working fine, but the ice tray is not filling up with water. I checked the solenoid that lets the water flow and thats fine. Is there a part that I could replace or is there some other common problem that could be addressed by myself. Thanks.
The first think I would do is check the water feeding tube into the ice maker for a possible frost inside. Then check the optics as described in the Service manual. Post the results. Gene.
