rollera
#1 Posted : Sunday, February 15, 2009 6:23:47 AM(UTC)
rollera
My oven goes from preheating as normal to a high broil within 5 minutes even though I had set it to BAKE at 350. I have tried changing the temperature - preheating at 200, etc, and the oven still goes into broil mode. Any suggestions would be helpful. Thank you.
TechnicianBrian
#2 Posted : Sunday, February 15, 2009 7:15:22 AM(UTC)
TechnicianBrian
I am guessing this never happened before? When this happens, does the broil indicator on the display illuminate? Does the oven ever reach the preheat temperature? Your oven cycles both elements to preheat the oven, but the broil should not be on long enough to actually glow red if that is what you are seeing. I am guessing at this point you may have a bake element that has failed so now you are only noticing the heat from the broil element during preheat. Get back to me with any other details you can provide so I can get you going in the right direction.
rollera
#3 Posted : Sunday, February 15, 2009 3:49:06 PM(UTC)
rollera
Yes, this has not happened before. The broil indicator on the display does not illuminate. The oven does not reach the preheat temperature, even though the oven indicates the preheat cycle has ended. The broil element does glow red. The bake element does come on initially (and glows). The broil element gets extremely hot (more so than if broiling). Thanks for your help.
TechnicianBrian
#4 Posted : Monday, February 16, 2009 5:49:29 AM(UTC)
TechnicianBrian
OK I seem to be missing something. You say both elements will glow, the oven preheat times out and says it's ready, but it really isn't. And the broil element get hotter than when it is broiling. Does that about sum it up? What happens when you set the unit to broil? The control board (AP3851248) is the only component in your oven that turns the elements on and off based on the information provided by the temperature sensor. You are not getting any faults, so I would assume the temp probe is OK, and it doesn't control the element directly at all. And just to clarify, no work has been done on this unit? It sounds like the broil relay is stuck in the on position so when you start a bake cycle, it turns on and stays on instead of cycling. Because the temperature jumps up during preheat with the broil element always on, the bake element will cycle off and probably stays off because the temperature probe says it's hot enough. If that sounds like what it is doing, then the control is your failed component. If you are seeing other things, get back to me and I will see what else I can come up with.
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
