mgoblue
#1 Posted : Sunday, February 15, 2009 5:42:51 AM(UTC)
mgoblue
Cannot get furnace to kick on-If I take off panels & push in the switch(which I believe the panel is supposed to do anyway) it will start-Is this just a bad switch or do I have other issues? Thanks, Mike
icehouse
#2 Posted : Sunday, February 15, 2009 3:13:34 PM(UTC)
icehouse
If you manually push in the switch and unit works then the switch is good.
Check the alignment of the panel.
