I Have A Wp Gold Qp Iii Dw & My Normal Light Is Flashing. It Did Quit Once And I Started A New Cycle And It Quit About 20 Min Into The Cycle And Is Flashing Normal Again. Any And All Help Will Be Welcomed!
Originally Posted by: AMY ONEAL  I Have A Wp Gold Qp Iii Dw & My Normal Light Is Flashing. It Did Quit Once And I Started A New Cycle And It Quit About 20 Min Into The Cycle And Is Flashing Normal Again. Any And All Help Will Be Welcomed! Amy, You most likely have a bad Normal wash keypad on the control panel. (see below) PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING RAPIDLY Stuck key(s) or shorted circuit(s) in keypad. Shorted circuits or connections on the control that read the keys. Here's how to reset the control board, when this occurs,
NOTE 1.
To start the Service
Diagnostics Cycle, press the following keys, in order, in less than 6 seconds, while in standby (off): Heated Dry, Normal, Heated Dry, Normal ** let the control board run the complete diagnosis cycle in order to reset **
And here's the part number you'll most likely need.
Part number: AP3774270
Good Luck, :) :) :)
