keokecandy
#1 Posted : Monday, May 30, 2011 6:01:11 AM(UTC)
keokecandy
I have removed the bolt successfully & there is a tower in the center of the arm; in the back of the sprayer I see 3-part white tab (looks like tail of an airplane), this is what I cannot release. If I don't remove the spray arm I cannot get to the filter. I've already removed the bolts on the filter as well, but cannot lift the top off to clean it out. I've had standing water & am sure the drain is clogged. Just bought this house a few weeks ago. Any advice? I'm using a mirror now to see the back of the arm. I also have pics if needed.
keokecandy
#2 Posted : Monday, May 30, 2011 6:05:07 AM(UTC)
keokecandy
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
