Gas range shows fault code "5ab"or possibly "Sab".Touch pad will not respond to any commands.The owners manual is not available!!!!
Hi TIMV
Your range is probably in the Sabbath mode. To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
