Have tried removing ice maker, but compressor won't run afterwards. Does the connector (fridge side) need a jumper plug?
THIS FORUM IS DEAD!!!!!!! |
Thanks for the help. If I had that spec sheet, I would've figured it out. Thanks again!:D
