ignighter lights but no gas. :confused: Also can`t find the model no.:mad: It is a single oven with broiler.
On my Magic Chef range with single oven, the model number can be found by opening the broiler drawer. Look for the label on the left front of the unit - not on the door itself.
the ignitor is your problem. it is weak, and does not have the strenth to open the gas valve. replace the ignitor. if you need a model #, pull up the top, where the burners are, and there will be a model # there. tom
