The lights do not indicate on the display when pushing any of the buttons. I removed the electric box cover behind the kick plate and found that the white wire had touched the black power wire. Heat from the black wires in the connector melted the tip of it, fusing the white wire slightly into it. What would this have effected and can it be fixed?
THIS FORUM IS DEAD!!!!!!! |
