after cleaning cycle, oven door still locked. clock hasn't worked for years.
Originally Posted by: afogelsong@gmail.com  after cleaning cycle, oven door still locked. clock hasn't worked for years. Afogelsong, You didn't reset the controls to off and attempt to unlock the door, did you. If I remember correctly, all the controls need to remain in the clean mode setting, in order to lock/unlock the door latch, then turn the controls to the off position. Try that and see what happens. :) :) :)
