Ds6Ck97
#1 Posted : 17 years ago
Ds6Ck97
We replaced the filter inside, but have no water getting to the ice maker, or in-door water dispenser.
kooler
#2 Posted : 17 years ago
kooler
Check to see if the water inlet valve (AP2115312) is getting power when the water dispenser is operated... One solenoid coil is for the dispenser and the other is for the ice maker... Some inlet valves have a small sediment screen where the water line connects that can plug up... See if this needs cleaning...
