qman3224
#1 Posted : Monday, November 5, 2007 4:27:42 PM(UTC)
qman3224
On our washer it will fill with water and it will timer will engage and i hear the motor but it won't agitate or spin but it will fill and drain with water i believe it is the belt or belt for the last couple of months if it is loaded heavy it use to squeal up untill today when it took a total dump am i thinking right by it being the belts?
#2 Posted : Monday, November 5, 2007 4:53:50 PM(UTC)
Hi qman3224
In order to provide the most accurate advise I need the complete model number of your washer.
