BALTAZAR RAFAEL CORTES
#1 Posted : Monday, November 5, 2007 3:52:31 PM(UTC)
:confused: IWANNA KNOW HOW I CAN INVERT THE COURENT FROM 240 VOLTS TO 110 VOTS COUSE THATS THE VOLTS RUNING IN MY BULTDING
#2 Posted : Monday, November 5, 2007 5:17:25 PM(UTC)
Hi Baltazar
If you do not have a 240V outlet in the laundry room your options are: to have a professional electrician to install such outlet or to use a gas dryer which needs only 120V.
Whirlpoo Dryer won't heat, tested most parts (Dryer Repair)
by everythingman 8/5/2009 6:56:39 PM(UTC)
