I need to replace the broken handle for a GE wall-hung microwave (like the space-saver). Screw at the top of the handle is exposed on the inside of the door. Screw for bottom of handle is NOT exposed. How do I get to the lower screw? Does the door come apart without being removed from the mounted unit? Thanks...
Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
